TwinTurbo.NET: Nissan 300ZX forum - Check water temp sensor, correct NGK plugs ? (n/m)
ttz'in (NorCal)
on October 15, 2014 at 1:40 PM
Bad misfire, hunting idle, no high idle on cold start up
posted by Hydrus (Dallas)
on October 15, 2014 at 01:08 PM
Hydrus (Dallas)
13:08:18 10/15/14
Check water temp sensor, correct NGK plugs ? (n/m) -
ttz'in (NorCal)
13:40:40 10/15/14
Replaced coolant temp for ECU and put fresh ngk iridium in.
Hydrus (Dallas)
13:42:11 10/15/14
Is misfire only one cylinder ? (n/m)
ttz'in (NorCal)
14:49:25 10/15/14
I would do a power balance test to determine if it is one
SammybTT(TN)
21:29:07 10/15/14
I replaced it with an autozone one. Picking an oem one up at
Hydrus (Dallas)
21:35:51 10/15/14
Re: I would do a power balance test to determine if it is one
Hydrus (Dallas)
21:37:19 10/15/14
Re: Bad misfire, hunting idle, no high idle on cold start up
Sportzcoop
22:48:31 10/15/14
Re: Re: Bad misfire, hunting idle, no high idle on cold start up
ttz'in (NorCal)
01:54:55 10/16/14
First item is power balance test (n/m)
SammybTT(TN)
12:46:40 10/16/14
Sorry shouldve made a list of everything ive done.
Hydrus (Dallas)
18:41:16 10/16/14
What were the results of the power balance test...?
-Grimm-
09:57:07 10/17/14
All cyclinders are firing and misfires continue.
Hydrus (Dallas)
12:41:26 10/17/14
Misfires at idle?
-Grimm-
17:23:04 10/17/14
Re: Misfires at idle?
Sportzcoop
23:18:50 10/17/14
They were on idle and under load. I knew it wasnt my injecto
Hydrus (Dallas)
17:26:57 10/18/14
